Southeastern NC | i have a 1980 1086.. with closed center hydraulics... tractor will only lift ( with 3 pt or remotes) when the engine is speeded up... at idle it will slowly leak down whatever is behind it... i have been told that this was probably not the pump in the rear.. but an internal leak... was wondering if anyone here had ever had a similar problem or knew maybe how to fix this???
thanks in advance | |
