Posted 2/21/2009 19:43 (#617736 - in reply to #617469) Subject: RE: 7110 trans pressure light
Eastern VA. No such thing as too many Magnums.
Are you sure you're not getting the "trans lube press" and "trans system press" switches mixed up. They are both under the floorboard and look quite similar. You may have changed the wrong sensor.
