Presently Running a IH 1480 and JD 9610 in small grains and oils seeds and grass seeds on 2300 acres. Kicking around the idea of going to one machine to make things a little simpler to manage. Money is always constraint. Would one 480 Cat combine do the same amount as these two machines. What are the good things about a 480 and the bad things about these machines?
