Posted 2/15/2009 17:32 (#610123 - in reply to #609961) Subject: Re: Quick release valve for air suspension dump?
NE SD
A regular quick release wouldn't work very well changes in bag pressure would trigger release, might hapen alot when moving . Air activated quick releases are used with supply line to leveling valve so when you dump the air it releases quick release valve for a faster dump.
