| I need a relay that is suitable for control by a microprocessor. I need an external 12 volt relay (less than 1 amp) that is controlled by the master application switch on a Land Manager. There is a 5 volt high/low wire in the master switch module. A std "ice cube" relay's coil draws to much power, and many electronic relays (have tried 2 already and am tired of experimenting) do not work reliably with 12 dc on the output side. I am afraid a reed type relay might not take the vibration. Any suggestions would be appreciated. | |
