NE Indiana | Well fiberglass is a good option but, is expensive. It has a lot of flex in it but, when it gets cold it gets brittle. Poly is alot less expensive and has good flex to it but can wear a hole in it easy if it is moved frequently. I'd say your best option would be the poly for the afordability and the monuverability unless it will be statinary. just be sure to keep the little pebbles out from under it. | |
