Pintle hitch bushing
   Forums List -> Where Can I find?????Message format
Posted 10/7/2018 09:57 (#7031183 - in reply to #7031019)
Subject: RE: Pintle hitch bushing
I'm guessing you want something between the drawbar and pintle tongue ?
https://www.maywes.com/products/draw-bar-savers
http://www.lundellplastics.com/harvest-products/hitchsaver.asp
https://www.tractorpartsasap.com/poly-hitchsaver-38-x-6-od-1-12-id-new-126929.html
If you mean an actual poly bushing the hitch pin passes through to take up slack in the pintle tongue I'm not sure that poly would hold up too well.
If you are wanting to take up pin slop consider a Terog Bull Pull
https://blackaceparts.com/hitches.php
