SW Ohio | I used Steffen teeth for mine but there are many cheaper alternatives that probably work just as well. I few tips for yours that i will change on my next one----Make the teeth direction opposing so you don't rely on the back plate to pinch the block, use lots of teeth, set them up from the bottom several inches so the teeth bolts don't snag a string, put a solid rod inside the tooth bar instead of a pipe outside for the bearing mounts, keep the overall height as low as possible to avoid hitting barn trusses, set the mounts high enough you can grab a block when it is in a low spot
(jacob clamp01 (full).JPG)
(jacob clamp03 (full).JPG)
(jacob hay WT 02 (full).jpg)
Attachments ---------------- jacob clamp01 (full).JPG (146KB - 49 downloads) jacob clamp03 (full).JPG (142KB - 52 downloads) jacob hay WT 02 (full).jpg (128KB - 54 downloads)
