Posted 10/10/2006 06:12 (#50076 - in reply to #49966) Subject: RE: JD 7700 combine tranny problem
When mine went a copple of years agoit took the splines off the hydro shaft so we had to take the hydro out and change the shaft and seals in it. You will need help to put the hydro back in, it is one hevey S>O>B.
