n.w. iowa | Having trouble reading correct yeild in a 9600. I clean out around the mass flow and seems to work breifly then falls out of bed. First changed the plastic shoe attached to mass flow, didn't work, next changed the mass flow, didn't work. Several years ago seemed to have the same problem so changed the processor fixed it since then upgraded to the mobile processor ran fine. Now changed that and didn't work. Moisture sensor would be next but it reads mositure fine plus I would have to trim some on a new one to make it fit. It reads acres, moisture just fine but ran lbs. check and it is way off, just not reading lbs. Any help out there. Also cleaned electrical ground on engine rail, dealer says there are a bunch of places to read voltage levels of other things to hopfully find problem. | |
