Posted 10/4/2006 17:56 (#48731 - in reply to #48702) Subject: Re: Ignore this post, I may have an answer. van warning light.
Brazilton KS
If you google the model of your vehicle along with trouble codes or ECM codes you will probably be able to find the proceedure for reading the codes through the check engine light, without having to use a reader. Usually it is some sequence of key switch and possibly column stalk switches to start it, then count flashes to read the code.
