Crawford County, Robinson, Illinois | I was given very good advice several years ago: whenever you have problems with any lighting on trailers or trucks, check all the ground wires. That advice has served me well, almost every time I have a wierd lighting problem, I usually find a corroded or rusty ground wire somewhere, or one that has been cut or disconnected. I have no idea if your problem is related to a ground, but it is something to consider. |
