Mid-Missouri | I understand the actuator frustration. I built a shield from poly that slides under each tilt cylinder end to keep dirt out of the pin linkage.
You can order the parts to make it a manual lock. I like using German Bliss for online parts and ordering, typically via phone.
I have a Perkins from our 7810 if you are in need of one. It isn't running correctly. I removed it from machine, 1800 hours, no leaks. I have heard it could be as simple as a head gasket but haven't opened it up. | |
