Posted 10/2/2006 20:57 (#48294 - in reply to #48254) Subject: RE: JD 1560 Drill update 4x4 sq tube
Driftless SW Wisconsin
We use a 4 x 4 x 3/8 A500 Grade B steel tube which is readily available from most steel service centers. Given the hassle and repetitive nature of these posted failures I would consider having a good local weld shop make one from the failed shaft and the above 3/8 tube. jmho.
