210 Industrial Dr., Arlington Wisconsin 53911 | Just so you are aware the 1780 uses two different style transmissions - a left and a right.
One side for seed drive and the other side fertilizer. I would do some research in John Deere
parts for your planter. I believe you also need a piston pump mounting plate? Both transmissions
look similar just the gearing is on opposite sides. I have both transmissions that are new. Located
near madison Wi. |
