Posted 3/16/2018 09:42 (#6644874 - in reply to #6644834) Subject: RE: Forklift Cylinder
I have a GC30 with a bad motor. Same forklift, different wheels. If you can find your mast serial number, we can make sure the cylinder is the same. Usually those numbers are above the tilt cylinder.
Also, for $500 you can have the whole forklift. We'll even load it on a trailer for you.
