mercer county, il | dultmeier sales in davenport carries them in smaller sizes, not sure on anything that size.
you could be cheap like me, I took 2 1/2 inch aluminum pipe sections 6 inches long and cut the top 1/3 out so the hose could squeeze down into them. make sure to round the corners and smooth the edges if you go this route. if you do not want the hose to slide just run a couple weld beads perpendicular to the pipe on the inside, keeps the hose from sliding. and use stainless screws to mount them. | |
