Washington, Kansas & Lincoln, Nebraska | Hi guys,
I hope you all are enjoying a productive safe harvest by now. I have this posted over on CIH Combine Talk show and will put it on precision talk as well.
I have a factory installed yield monitor with GPS in my '96 2188. I upgraded to the Trimble 2400 in about 98. It has been losing it's differential signal sporadically for some time now. This fall it's constantly cutting in and out. I am set manually to the KC Coast Guard Beacon for differential signal. I went to change this a couple days ago and my screens are scrolling so fast that I can't enter any of the menus. None of the four buttons on this unit will do anything to it.
Does this mean it's time for an overhaul or is there a quick fix? If overhaul, where and how costly?
Does satellite differential signal require a subscription for this unit? If so, how costly? TIA
Edited by Larry NCKS 10/1/2006 15:42
