Northwest IOWA | There are alot of "used " floors around the country , especially if your only needing a 14 ft dia...Giving a location would be helpfull too. Iv helped install an older floor out if a 36 ft bin into a 24 and 27 ft bin . Many of the used floors in this area are the older Chisel Cut 7 inch planks, not fun to sweep , but easy to clean up w a Stihl Leaf Blower. Often Bin Builders will have a bunch of used floor stands around too. Put an 8 or 10 in unload tube under it . A project like this would be a day or less work to do ...Good Luck... | |
