SW MO | JDNWA - 1/1/2018 20:55
Honestly wheat farmer, I think it is. I put about $200.00 into it and got it back going. Since then I’ve put about 100hrs on it and most of that was pulling an 11 shank Glenco disk chisel as deep as it would go. Everything works as it should. The a/c still works but that cab don’t keep the bought air in. So I was just thinking about a cab swap and a little tin and away we go. Cheaper than 30k for another one.
That makes sense, just curious. What kind of ground are you pulling the glenco in? Pulling the 9 shank with the 8830 in our prairie ground and bottom ground really worked it, wouldn't want to try an 11. |
