I'm going to pull a 2210 with a caseih quad and need the kit to make accudepth work with this tractor. It will have a 2630 in it for guidance so I assume I can run the accudepth thru the 2630 so I'll need the valve on the fc and the switch in the cab with harnessing. Call or text 815-291-3684
