Posted 12/19/2017 07:04 (#6439004 - in reply to #6435545) Subject: RE: 1-2” auger for moving corn to corn burner.
LakeLillian, MN
Thank you,
I have the same furnace with a 15bu hopper next to it. I don’t have much gravity to work with, but I was planning on using a pro box as well. I found a couple old pro boxes that unload out the side. I like burning corn also. It works well for our house and I only burn a couple hundred bu a winter max. I always worry about a motor going out and where I am going to find a replacement. But until then:)
