Winkler, Manitoba Canada | smcewen - 12/16/2017 05:43
Tractor has had a 50 series update, but with no mechanical tach drive, has to be electric. Was told JD offered this back when they did a lot of the conversions. Anyone know the part #? TIA Shawn
If the JD connection does not come through, Isspro has electronic tachs and pickups. Link is to a vendor of said product.
http://farmtronics.com/proddetail.php?prod=E04700
Not knowledgeable on JD but can the mechanical tach drive part # RE29234 be added to your engine so you can use the original tach?
https://www.tractorpartsasap.com/Tachometer-Drive-Assembly-p/499340....
Edited by WTW 12/16/2017 11:17
