I'm looking for a controller that will manage Tru-Count clutches for our planter. I called Ag Leader to ask them what the differences were between the Insight and the Edge. One of the questions that I asked was "will I be able to use the Edge with Seed Command for the planter and then later on with Direct Command for the sprayer?". His answer was yes. I'm now looking at the "Display Comparison" tab on the Seed Command page of Ag Leaders site. The following image is displayed: As you can see, towards the bottom there is no 'x' in the Edge box on the "combination of SeedCommand and DirectCommand" line. Does this mean that you cannot use Seed Command and Direct Command simultaneously with the Edge or does it mean that you cannot have an unlock code for both Seed Command and Direct Command on the edge regardless of whether you want to use them at the same time or not?
