roaming | Sure. Large Tractor software will give you up to 6 cells of tractor data on the left side, and then you can set up your RUN screens with any combination of data from the planter, tractor, guidance, mapping, etc. Large Tractor can only be used with the newer series of Case IH and New Holland tractors that have a secondary CAN bus.
Generic Tractor is similar, except it doesn't communicate with the tractor at all, so the left area can be used for whatever you want. | |
