Creighton, NE | Suction screen is on the right hand side of trans where that bigger steel line goes in from the hydraulic pump. You have to take the suction line off the pump and then there is about about 6 bolts or so to remove the screen from the bottom of the transmission housing. Takes a gasket and couple of O'rings when doing that job. This is on the later 71xx series with two hydraulic filters, I'm not sure if it's the same on the earlier ones that only had one filter. | |
