SE Wisconsin | What the monitor is telling you is that you are still recording the data in farm 1 and field 1. So basically all of your points have been going in the same field and farm. Unless you change the undefined 1 to another field you will be recording all of the data in the same field. It depends on the program you are using where it will put the points. What program are you using to export the data? What version of the GS1 software are you using? If you need help you can always go to this page at Stellar Support. http://stellarsupport.deere.com/en_INT/products/original_gs/ogs_om.... | |
