Posted 10/20/2008 03:31 (#486289 - in reply to #485936) Subject: Re: Centerline 220 questions
For seeding you should use higher accuracies. I would recommend OmniSTAR HP/XP or even RTK. Also look at the antenna of the 220. It is comparable to Trimbles patch antenna which comes along with EZ-Guide 250 if you donĀ“t want to use the recommended Ag15 antenna. Trimble says EZ-Guide 250 with patch antenna provides you submeter accuracy, with the Ag15 15-30 cm.
