Trenton, MO | i recently put an autopilot on a case 2588 and 2388. it was a full install on both, but when i went to calibrate the 2588, the deadzone's were in the 50's, and after doing the p-gain, you would try to engage on the line, and the wheels were overworking way way to much. It would shake you in the cab, they were working that much. After talking with Trimble tech supprt, we manually put the dead zones around 30-35, and it stopped the wheels from over working, but it's still doing some wondering on the line. Then did the 2388 and it did the same thing the 2588 was doing, it would give me deadzones in the 50's, but had to manually put them at 30-35 to make it drive. i thought it was weird i had the same problem on both combines. Has anyone else had problems like this on any Case combines? | |
