Posted 10/15/2008 15:18 (#482954 - in reply to #482696) Subject: Re: Is there such a thing as a 315/24.5 steer tire?
Near-north Ontario, French River
Whats your axle rating? I suspect if you are running 11r24.5's now that you have a 12,000lb steer axle. Unless you intend to swap out axles as well I see no point in moving up to tires that would allow you to carry 10k each.
