| Yes I have just a CharLynn motor mount motor on end of auger flight shaft make a L bracket out of some 2" flat bar notch out to fit around motor shaft use 2 bolts seemed fine then on auger tube make a U bracket square corners L bracket from motor runs in the U bracket on auger tube to take out startup shock and any wobble and keeps motor from spinning around Hope that makes sence LOL | |
