NE SD | Under the "Greenstar 2 Pro-Menu" select the I button. Select change harvest settings and change the crop type to Corn. You may have to go into original greenstar emulation mode and change the head so that it is the right width etc., or do you do that in the armrest of the 70 series? Either way, your harvest settings has to be set to "Corn" or else it will kick it back to whatever it was set for (likely platform) each time you cycle power. | |
