| Did it on a STX 275 with accusteer, had a major shimmy problem. Tried plumbing it into the front axle only, still shook like crazy. Plumbed into the main hinge it shook like crazy there also. Gave up and moved everything over to a 9270 workes great, same valve,same e-drive,same everthing. The only thing I did was put the antenna out over the front axle, couldnt work better. Ended up putting Autopilot on the STX, but we blocked the front axle cylinders so that the axle was perfectly straight and the antenna is over the center line of the front axle. I think the answer lies in keeping the front axle square with the direction of travel and having the antenna out over the center line of the front axle. Sensitivity on the e-drive is set on 4 for the 9270 and the flow is set very low. | |
