Posted 10/6/2008 00:19 (#475736 - in reply to #475659) Subject: RE: 2388 rotor engage switch doesen't always work?
NC IA
Could be a voltage problem, try shutting off your lights and AC and cab fan, then try it.
Had my valve capsule go bad this summer, but it was an early one with the PTO clutch. I don't know if the belt engage machines use the same valve or not.
