SE Iowa | A-gate, could you describe your setup? What are you using as a flight app? What overlap percentage are you using? What altitude are you flying? How are you processing the imagery? ARe you using the global or rolling shutter?
I've had success with the Sentera, but on a fixed wing. I flew with 70% overlap. The sentera has a bit smaller field of view than the Phantom camera, so sometimes the overlap percentage is higher. I'm also using the 1.2 MP global shutter rather than the rolling shutter.
I actually processed it through DroneDeploy, and it worked great! The only thing you NEED to know is that DroneDeploy sees Sentera as a competitor, so they didn't create a lens profile for the sentera. So DroneDeploy gives a good stitch, but the NDVI is completely screwed up. I exported the stitch and imported it into AgLeader SMS and ran the NDVI there.
I would LOVE to see DroneDeploy support that filter
