wc in | my farmer friend got this grain cart and the unloading auger works but it goes out very slow. the hydraulic cylinder has to close in order to raise the auger which he thinks is acutally the wrong way for the power it needs to raise the auger.is this common among grain carts? does he just put up with it. we changed the hyd lines around which did no improvement. the same configeration was on the 6600 combines which did not work very well either. | |
