Posted 10/2/2008 01:15 (#473483 - in reply to #473421) Subject: RE: Versatile 936 and John Deere 455 drill?
NW Washington
If you get it hooked up correctly your 936 with PFC hydraulics should run the hydraulic down pressure just like it is supposed to operate.
Where you get in to trouble and have to use a work-around lash up is when you pull one of these JD drills with a tractor with an open center hydraulic system.
