Shelby, MT | will have to look,at it. Something else that happened to us was on the joystick. it attaches with a knuckle/ u-joint setup there in the console. well dad was driving it on day 2 or 3 and he complained something was loose and he pushed forward it was loose and would only go so fast. well I tackled it the next morning and after getting the bottom cover off the console I see ther is a single pin that slides through the knuckle set up and it was almost out and would have com out if it wasn't spring loaded for side to side movement.....well the cotter pin was never installed......could have been a shock to be driving and then have the joystick fall off....other than that no break downs so I guess can't complain....
Hey I guess I missed you at the steakhouse...I was there Sat and had the s l o w roasted prime rib...what a place!!! | |
