SC North Dakota | Make sure gear box has oil, I change it every couple of years. 2nd check the knife head that one side is not broke where the bolt attaches to the gearbox. 3rd check the rubber bushing in the part that the bolt that mounts the knife to the gearbox. 4th check the mounts and mounting bolts that hold the gear box to the frame. Have seen the lugs broke off the mounting foot. 5th check coupler from hydralic motor. I use a dial indicator to true the motor to the head. Box will run warm to hot. Have not checked mine with a infared thermometer.
hth
Is the sickle in time with the guards?
Edited by dakota 9/23/2008 17:37
