Posted 9/23/2008 13:38 (#467438 - in reply to #467294) Subject: Re: Rogator booms swing too fast
Any hydraulic shop will supply you with relatively cheap orifices to install at the control block. Unhook either hose, remove the port adaptor, thread the orifice into place, put the adaptor back in, hook up the hose. Start with a 0.093, see if it fixes the problem.
