Posted 9/21/2008 22:53 (#466195) Subject: Drawbar Support for CIH 7120
I have read that using a 3/8 chain from the lift arms to the drawbar works well to take out the "flex" when pulling heavy implements. If the chain support is used to help support the drawbar on a grain cart with PTO is there a risk of catching the PTO shaft with the chain on tighter turns? I typically have a fairly inexperienced driver in the grain cart.
