Posted 9/21/2008 11:20 (#465659 - in reply to #465629) Subject: Re: Need a little engineering assistance.
Janesville
Like Ernie said, what if you put a psi. gauge in the system and get a psi. reading when you know that it is operating normally. Then get a pressure relief valve and set it for a couple hundred pounds more. It might take some time to get it set where you need it but might be another option.
