Changed the on/off button and swapped out the enable unloader relay but still won't shut off till I swing it into the saddle. Even then, after it's off, the monitor says I'm still unloading. Beginning to wonder if I've got a "mouse" problem somewhere. AC fan stays on high even after changing the relay switch as well.
Any suggestions on the unloader?
Thanks. Dan
