Sumner GA, Located in southwest GA, | If you want to use a lillistion, bush hog, or older two row picker, buy 2, because one is a parts machine. Bush hog provides NO SUPPORT for lilliston pickers. We got a HI CAP that is out of commision with broke strawwalkers, and If you want those things new, you have to build them yourself. Sorry I cant give you any good news, but the only things that you can buy for them is the teeth, bearings, and belts, and maybe if you luck up, some pickup parts. |
