Posted 9/20/2008 22:52 (#465380 - in reply to #465356) Subject: Re: How to do a check with GS2?
Loads can be tank, truck load or field. Tank is auto incremented when unloading is engaged then disengaged. Truck loads must be manually advanced. Field loads increments to the next load when a new field is selected. I do not believe you can restart loads at number 1 as they are automatically assigned by the monitor.
