Adams, MN | Repeatabilty is very good. Have not nudged, shifted or recentered for over a month. Installation is simple and straight forward. All of the connections on the back of the factory radio are the same as those on the Mojo. A couple of antenna cables and run the little twisted pair to the GS display. On the 8x30 and 7x20's it's even easier if you don't use a GS 1 or GS 2 display. That makes for a simple install and very accurate straight line steering system. | |
