| I'm having problems getting the field tracker or the header to flex on a gerinhoff. Middle sensor is the height and the two outside ones are the field tracker, right? I looked in the book (2388) and it said to drop the header, hold it down for two seconds then click it up, it should only lift a foot.
I ran a 2608 last year and couldn't get it to flex/track either. Works fine on the 1020 though.
Why does it care that its a differnt head. Should be no different than the flexhead, right? | |
