Posted 9/18/2008 07:05 (#463332 - in reply to #462275) Subject: Re: CaseIH yield monitor problem
Flora IL
Also remember if they redo your monitor then u will lose all your cal data... also get a new card that's a smaller card but sits in a adapter to go into the slot you already probably have....
The smaller card is alot more common and most 6-1 card readers will read it... then you just plug it back into the adapter and put it in the combine monitor.....it sounds like ur cards took a dump.
