Central, IA | I have an original starfire that I used to provide position to my Insight this summer for spraying. In order to get the NMEA out I had to shut off RTK on the receiver prior to hooking it up to the Insight. (wired direct to receiver, no Tee cable used). Now going back to the tractor where RTK is needed, is it possible to have NMEA out to the insight and run RTK if I buy the Tee cable from Deere? I think I've found that it is possible with an ITC, but I'm wondering if anybody has tried it with an original. | |
