Macoupin County IL | I have problems with my AFS software last year I put some loads under the wrong field name after I processed the card
I tried to correct the problem with the spatial sorter under the tools menu. Now the information from 4 fields over 7years
is all in one field. Is there any way to sort these loads back to the proper fields.
I plan to rename the farm that these fields are assoiated with this fall so that I get good info this fall, should I remane the fields also,
Any help would be appreciated | |
